Discuss Niceic certification in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
cliffed
Supporter
DB not connected directly to the main supply.
The confusing bit, characteristics at this DB, is this still related to the Distribution circuit.
You can actually read it both ways, I’ve been entering the Distribution circuit but now have my doubts.75F9686E-7EA8-4BD6-A0E4-2DAE14CC9087.jpeg
You've been doing it right. It's the Zs and PFC of the distribution circuit as measured at far end (the sub-main consumer unit)
This then gives you the base-line if you want to fabricate calculate Zs readings from the R1+R2 readings of the final circuits.
It's self explanatory. You're selecting an existing DB, then a sub DB, then entering the details for the sub DB and then the test results at it.
A distribution circuit is feeding the sub and needs listing as an out going circuit from the main DB.
Hope it helps.
Reply to Niceic certification in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Not sure whether this is the right context or even forum to mention this, but I’ve recently been offering out myself to a friend to help get his...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
