Discuss Out door cable for lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hey guys
Would like recommendations on what type of cable you guys would run for outdoor lights which are covered by a porch ceiling. ( if that makes sense )
The cable would be clipped direct.
Would you guys recommend pond wire which is water proof or SWA or even normal flex wire ??
normal flex is fine esp. if out of the weather. sunlight will slowly degrade white flex. black is better. if in doubt, use pond flex (or silicon flex) to be on the safe side.
flex is waterproof. the stripped ends are not. o_O
PVC sheathed cable may have water resistant properties however, PVC is not waterproof. If submersed for a period of time water will penetrate the PVC.
think the word "weatherproof" would be a better description than "waterproof" in relation to pvc flex.
Reply to Out door cable for lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
