Discuss Oven and cooker circuits in the UK Electrical Forum area at ElectriciansForums.net
Jack a 7.4 KW hob will draw max 32.2 Amps and a 5.8 KW oven will draw Max 25.2 Amps you will need to apply Diversity to those calcs, best advicget an Electrician to design and install circuits to suite the needs.Hi i have a double oven which is 5.8kw and induction hob which is 7.4kw there currently isnt a cooker circuit in the house but there is 2 spaces in the CU so am I correct in thinking I can put 2x32A breakers in and run 6mm cable to both .
on his profile ,he say he is ,but any good spark. would have work out that before asking .Are you an electrician because this is notifiable work.
His profile says Quals Part P & 17th so not to be rude to the OP this should be well within what he has been taught. I am hoping that the OP knows the answer but is doubting himself.Are you an electrician because this is notifiable work.
That will be all down to Part P then Ant cus the 17th teaches you jack all, except how to pass an exam. Neither qualification will class you as an Electrician. Well maybe it does these days. Part P is a building regulation NOT a qualification.His profile says Quals Part P & 17th so not to be rude to the OP this should be well within what he has been taught. I am hoping that the OP knows the answer but is doubting himself.
I bet the op thinking ,o f88k ,they are on to me.And if the location is the OP''s postcode, then Wales have the stricter Part P rules to contend with too.
I see the OP's been back on and not updated us as yet .......
yeah wright ,I would has well .got court with you pants down .Hi all apologies I am new to this so always second guessing myself. I am not doing the work myself getting another spark to I was just seeing if my logic is correct
Caught, not court, didn't you learn owt at school? Court is where he might finish up. ---- me the grammar on here doesn't get any better does it, quite apart from the idiot OP's......yeah wright ,I would has well .got court with you pants down .
Caught, not court, didn't you learn owt at school? Court is where he might finish up. **** me the grammar on here doesn't get any better does it, quite apart from the idiot OP's......
new circuit ,if that's the case .Is it?
I thought kitchens were removed from the notifiably list?
Not stating... questioning
Reply to Oven and cooker circuits in the UK Electrical Forum area at ElectriciansForums.net
