Discuss Oven controllers in the UK Electrical Forum area at ElectriciansForums.net
I have been called out to 2 problems with ovens (not the normal need to reset clock) after a power cut the oven controller screen was blank as if no power going to oven, checked them out and power to everything up to the electronics , power into that but nothing else, seems the board is dead but 2 days later it comes back to life all by its self, I then had the same happen to my oven, first time it took a day to come back second time a week, my one is a Brandt (made in France) others cheap units not sure of brand, anyone had same problem or a idea of what it is and why it comes back to life?
I haven't seen this problem with ovens but I do have a theory...
I have seen this problem a few times with electronic appliances, mostly micro processor controlled items, where they really do not like power cuts / surges and stay in non operational 'locked' state, sometimes indefinitely which is why a lot of electronic stuff used to have reset buttons
Normally resetting the power will 'reset' the memory or any locked state, ie: disconnect power completely including any backup batteries if present and leave off long enough to discharge any on board capacitors
Maybe a stupid question but have you tried a power cycle on the circuit?
As I said I haven't seen that problem in ovens but it's a possibility what i've said due to the electronics in the controller
Hi thanks, I tried power cycling many times, connected both phase and neutral down to earth to fully discharge any capacitors in system (no battery) I left off for short time 5 seconds , long time 2 to 3 hours, the real question I can not work out is why does it restart in a day or so?
Reply to Oven controllers in the UK Electrical Forum area at ElectriciansForums.net
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi, Just been scratching my head about this one and wonder if I've missed anything. A few weeks ago I installed a new circuit for a 3kw oven and...
Hi Our oven stopped working suddenly including the clock. It was on the fan oven setting at about 150 degrees. I checked the fuse board - it had...
Hello All. I have a Westinghouse pxr6988 wall oven. It has a cutting out problem when using it in Keep Warm mode, it heats ok and stat is working...
