Discuss Pass or Fail in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Q
QSGAZ
Found this following a generator install, is this a pass or fail? what condition should these earth rod containment systems be in? is the a regulation? upload 2.jpgUpload.jpg
Found this following a generator install, is this a pass or fail? what condition should these earth rod containment systems be in? is the a regulation? View attachment 10709View attachment 10710
Why would you want to fail these purpose made earth rod pits?? The only thing i can see that needs improving is the protection of the actual cable connection to the rods. and to the connections to the earth pit bar. Something like ''Denso tape'' (preferred) or self amalgamating tape around the rod connection and the bar connections. The earth pits don't need to be waterproof, in fact it helps if water can enter and seep through down to the ground where the rod is positioned. Though in this case it seems the water is trapped in the pit.
So, not a fail but could well do with some comments. Such as those pointed out above and maybe some holes drilled in the base of the pit to allow water to escape. Both these earth pits should have covers of some sort over them, even if to just stop the leaves getting trapped in them ...lol!!!
I was thinking that the water could probably do with some salts being added, to increase conductivity.
I take it that this is a TT installation, and the rods are not for the lightening protection?
Thats what i mean i wouldnt fail, would it need improvement to a bs7671 (code 4) or requires improvment (code2?) , yeah its TT. theres four of these surrounding a generator.
by their nature earth pits fill with water If your worried denso as suggested only other thing Id worry about is Mr ,Mrs jones walking down the street and sticking their foot in the pit breaking his,her leg falling banging her nose hence ruining her topless modeling career and claiming the guy who tested the installation 5 years previously
They shouldn't be filled with standing water mogga, the water should be able to leech away over the rod. This pit looks as if its been set in concrete and escape of the water at best, far too restricted if not impossible... But nothing a few drilled drain hole won't fix...lol!!
Reply to Pass or Fail in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Hi All, My colleague and I are currently doing PAT/ISITEE Testing, and we've hit a snag with a bit of equipment - we've got 19" Racks for our...
Hi everyone Sorry if it's a repeated question tho. Agents followed me a failed visual EICR which has C2 for lack of RCD on cooker circuit and...
attempted the am2 march 2022 passed A1/A2/A4/A5/C had a lot going on at the time death in family so never got back on this i have till march 24...
Performing the PAT inspection on some science equipment and I have found some items that were passed by the previous company that performed it...
