Discuss Pir and switch setup in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I would split the circuit into the two groups of three and hard wire the three you want switchable to a switch with a contactor to bypass the switch with the contactor being driven by the PIR.
Its quite straight forward, as long as you can get to the feed of three lamps. Once you have separated the 6 lamps into two separate sides, you'll need the feed to a SP2W switch and a 3-C sable from the switch to the 2nd PIR.
I'll leave it to you work out the solution of the connections to the switch, PIR and lamps....
Reply to Pir and switch setup in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
