Discuss PV Sol problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
moggy1968
Wonder if you might be able to help me with a problem that has cropped up with PV sol.
I was using it fine this evening, then later when I tried to start it an error message comes up saying it is not a valid win32 application. I can't even open old projects.
Any ideas?
its probaly the database engine already running in background as you had been already using it previously, its windows, there are no explanations, and only one remedy, reboot computer and lose all unsaved work, I have moved over to IMAC now, not one error in 8 months! I bet Bill Gates is now using an Ipad.
tried rebooting several times, still same problem.
Make sure you get (and pay for) your annual updates on the mac, or you'll find you suddenly can't get them anymore and new stuff won't run!
Any ideas?
It sounds like the executable image (.exe file) has become corrupted. You'll probably need to reinstall it, I only hope you have an option to preserve any user data for the application.
oh bxxxxx
I thought that might be the case. Just moved house, the CD is in a box somewhere and quotes to do this weekend - arrrgghh!! Oh well, back to powerpoint drawings!
Reply to PV Sol problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello everyone. I have a inverter configuration problem I thought someone here might be able to help with. I'm not looking for a specific solution...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi I have problem wiring up DOL starter Circuit trips breaker when try to start I must be wiring something wrong Any help would be appreciated
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
