Simplyclean
- Reaction score
- 0
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens to get heat to each compartment. I was cleaning ceramic hob when power tripped. No big deal I thought, usually a bulb or faulty element. I turned off all switches on cooker, turned red cooker switch off and went out to circuit board and turned breaker back on. When I went to turn on red cooker switch beside rangemaster back on, straight away it turned off and tripped breaker again.. I switched red switch on socket off again, made sure everything on cooker was off and tried again but kept tripping. With red switch off, I turned breaker back on and pressed reset button, and immediately tripped. (with red button beside cooker at off)... Tryng to get someone to look at it tomorrow - where is fault most likely.?? Thanks
