Ohmless
- Reaction score
- 8
Hi folks.
I don't normally enter information on forums but here goes, in case it helps someone.
Two RCD peculiarities solved:
1) RCD tripping randomly + Solar panels Feed in Tariff.
After all usual checks and many frustration weeks eventually deduced tripping mostly coincided with dawn and dusk particularly. Solution was to run solar feed-in through its own mini (RCD) consumer unit. Yay!
2) Garage/workshop Consumer Unit RCD tripped (and tripped main CU. RCD) but the garage RCD would not reset. Carried out all the usual checks (these can be found on numerous helpful threads) to no avail. Contrary, however, to many listings that advise that RCDs rarely go wrong, and one professional site advising that if the RCD won't go back on then the fault is definitely within the circuit (s) 'because a RCD is at fault only if it doesn't trip' - yes, the RCD was at fault and it was that which actually tripped the main CU RCD! Replaced the offending item and Bingo! - And there were no faults on any of the garage circuits...
..ho hum, so put them all back together again
