Discuss rcd protection for sockets with cables <50mm depth in the Industrial Electricians' Talk area at ElectriciansForums.net
i think that you dont require RCD protection on these circuits if it enclosed in earthed metal conduit.
would the same apply to SWA cable? could that be interpreted as an earthed metal conduit if you earth the armourings?
commecrcial and industrial premises wouldn't normally have the same sort of wiring and layouts as domestic, most installations in a commercial or industrial environment would require a degree of mechanical protection. conduit, SWA & trunking would offer this.
note the above are assumptions and i would still advise more research to find definitive answers
does this apply to all domestic/commercial/industrial?
please state / quote regs / why
yes it still is requiared ,as for reg no it is the whole book as you cant use the bits you feel you want
the only way of not using this reg is if a instructed person IE a person under instruction are the only peaple who perform any work in property so may be comertual work can be emmited
sorry, i'm not really sure what you're saying there beaver...
can anyone translate? are you saying that as long as someone isn't an electrician and is under construction then they can choose to ignore current building and wiring regulations??
Reply to rcd protection for sockets with cables <50mm depth in the Industrial Electricians' Talk area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Evening everyone… I’ve attached pictures for your leisure.. so basically the customer does not have any RCD protection.. 3036 fuseboard is in...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
So I'm getting various responses to this depending on how things are interpreted. Here's a scenario: Assume property is a tenanted property...
