Discuss Recording test results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bigpaul
Hi New to electricians forums,
I need to issue an electrical installation certificate for the addition of a 3 phase D/B to an existing installation
I gone back to the mains and recorded all earthing/bonding. no problem.(Switch room 1).
The new DB is fed from a fused switch locate in switch room 2
However i need to record the test results for the new DB (located in NEW switch room 3). 16mm SWA + seperate 16mm cpc with 80A main switch. How do i do this?
Reply to Recording test results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Evening everyone, I was taught when carrying out Zs testing to test both L-PE and L-N and record the highest result of the two tests for my Zs...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
