Discuss Reset SMA SB1700 gen counter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
V
VMan
Hi guys,
Is there anyway to reset the generation counter on an SB1700?? i'm assuming i may need the sunny explorer?
Cheers
You can do this using Sunny Explorer (assuming that the SB1700 has the bluetooth piggy back installed). Logging on as installer (default password 1111) allows you to change both yield and running time. Logging in as user (default password 0000) just yield. (Settings found under AC side settings).
Reply to Reset SMA SB1700 gen counter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Gents, I swapped a Sunny Boy SB1700 which stopped working, with a Sunny Boy SB2000HF-30 which came from another plant. The SB2000 ws working when...
Hi. I have a single phase water pump which supplies our house. It frequently cuts out and needs to be reset (on pump itself). Because of our...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Hi all Called to do an EICR on a property 4 studio flats / bedsits within a single house. The t&e sub main to each flat runs within the fabric of...
Hi I'm supervising maintaining a building powered by a 1250 Amps and i had a total blackout twice within a week. Checking the MCB and it's...
