Discuss Schedule of Test Results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nickbrom
Hi hope someone can help...
I am fitting a new Shower to existing CU complying with all requirements... On the schedule do I only list this new install as i havent altered any of the others. For info It is 10mm cable via a 40amp MCD to the CU's RCD
cheers
Nick
EIC for your new circuit. ensure earthing and bonding is intact and adequate. any problems you see with the rest of the installation, note in comments box.
Thanks for the replies... If i do list the rest am i required to test and list the results?. I dont have a prob listing them but didnt think i have to carry out any testing on them or is it purely a visual check? there are approx 16 more MCDs
telectrix i have carried all what you have referred to
you do not have to test or inspect any circuits you have not worked on.
if you are listing all circuits on your test schedule, you can enter N/A for the readings boxes.
i wouldn't list the others even - I used to mark the other circuits as n/a, now i use the Amtech package and that has a 'Circuit not tested' fill for the circuit descrition box, like spin says, it may confuse matters - do you know the other circuits are marked correctly?? IF you list them you may need to check!
Reply to Schedule of Test Results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
Would entering each RCD as a line on the schedule of test results be correct? If so, what would be entered in boxes such as Zs?
This is slightly pedantic, so right up my street. I'm filling out an EICR. The sockets are wired in 2.5 (apart from some in the kitchen that have...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
On a couple of recent EICRs I've run into FCUs on a RFC, then 1.5 or 1mm to several lighting points and would be interested how people would note...
