Discuss Screened compartment trunking in the UK Electrical Forum area at ElectriciansForums.net
Look at reg 528.1 it states 'that every cable or conductor is insulated to the highest voltage present' , if run in the same trunking ,As for screening this is normally part of the cable to prevent interference for example SY cable
When you say Screened Compartments do you mean this?
Need to post more information up regarding the job to be honest.
Most screening is just a divider in the trunking, also who spec'd/designed the job as thats down to them to specify in the job spec.
I know they shouldn’t be together in the same compartment but sometimes it’s unavoidable and crossing occurs. Also on long runs of cable tray you have the same issue.
Disagree with the cable tray, i have never seen ELV and LV run on the same tray, you can cross through the dado and use a divider to separate the cables. If your using dado why cant you keep them separate?
They can’t be kept seperate due to the way it’s been designed. I’ve very rarely seen seperate tray runs for elv cables. You can get more than adequate separation on cable tray but like I say, occasionally they will cross over
Anyone come across screened compartment trunking before? If so is anyone aware of any specific reg governing the use of this, in regards to length of run allowed for lv cables in elv side?
Yes I’ve used it.
Not aware of an specific or non-specific Reg governing it’s use.
If ELV and LV cables are run in the same containment, the insulation of both should be rated at the highest voltage.
Rule of thumb, is that data and LV cables should not be together for more than 1 metre.
Yes I’ve used it.
I had a metre in my head but wasn’t sure if it was a regulation or not. So it’s just a rule of thumb. Thanks for clearing it up.
Reply to Screened compartment trunking in the UK Electrical Forum area at ElectriciansForums.net
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Morning, Company had an external contractor coming in to complete an EICR recently. They have gave us the report with a C2 for holes in trunking...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Is it acceptable to run mini trunking as shown in the pic? To my mind it would be safer (and slightly less ugly) to have a drop from each socket...
