Discuss Self Lm of transformer in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Ridley Engineering | - Transformer Measurements - http://www.ridleyengineering.com/hardware/ap310-analyzer/ap300-application/transformer-measurements.html
If by self-induction you mean Lm, you need to measure the frequency response of the transformer to estimate/measure the magnetising inductance (Lm). The article above shows you how. Measuring Lm at a single frequency is no good because a SMPS uses pulse waveforms with a wide frequency band (sinx over x shaped). You need to measure Lm over the band of frequencies at which the the SMPS transformer operates.
If by 'range' you mean frequency range then steel laminated cores are used in power transformers operating at low frequencies 1-100 to 1000Hz say - I don't know the exact upper figure -whereas ferrite is used at high frequencies 1-100kHz because its hysteresis and eddy current losses are much less than steel cored transformers. Hysteresis loss is related to the areas inside the BH curve times frequency. Steel is a soft magnetic material (easily magnetised but not easily saturated) and has a 'fat' hysteresis curve whereas ferrite, a hard magnetic material, has a 'thin' curve' see attachment (hard to magnetise but easily saturated). A thin BH curve is required for energy efficient operation at high frequencies hence the use of ferrite transformers in SMPS applications.
Research Center for Magnetic and Spintronic Materials - https://www.nims.go.jp/mmu/tutorials/soft&hard.html
In a transformer the eddy current loss is proportional to frequencysquared - ferrite cored transformers have higher resistivity than steel ones which reduced the magnitude of the eddy currents and hence Ohmic losses (IsquaredR).
This is about as much as I can remember from my degree but hopefully will give you some pointers on further reading.
[automerge]1574499854[/automerge]
https://www.eeweb.com/tools/coil-inductance?utm_source=AspenCore&utm_medium=ELECTRONICS TUTORIALS
Permeability (electromagnetism) - Wikipedia - https://en.wikipedia.org/wiki/Permeability_(electromagnetism)
The loop inductance is:
Lloop≈μoμr(D/2)⋅[ln(8⋅D/d)−2]
The permeability (uour) of steel is higher than that of ferrites (see table in second reference) so the loop self inductance of similar sized single turns (same diameter d of wire, same diameter D of loop) is higher for steel than ferrites.
Reply to Self Lm of transformer in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hi there, firstly wishing you all good health and happiness 🙂 Just a few questions if you all don’t mind answering for me please.. I’ve just...
OLDBOY
O
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Electrical Courses
