simonmx23
Hi all
I am fitting a oven with a separate electric hob
Oven is 3400w so going to use 10m of 3mm twin and earth on a 16a mcb
Electric hob is 6500 so 10m of 6mm on a 32 amp mcb
Question is do i have to fit 2 cooker out lets and 2 dp switches or can i run both oven and hob into 1 cooker outlet and 1 dp switch
Obviously i will have to up the cable and the mcb
So 10m of 10mm twin and earth on a 50a mcb
So what does yous think
