Discuss Shed wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
davie25
Am wiring a shed ,One power and one light circuit,am putting a little fuse board in the shed,do I need a main switch or can I get a RCD main switch??The cable is RCD protected at the main fuseboard and I am using MCB in the little shed board,any ideas,cheers
Are you sure about that?? I tought the shed had to be seperate to the house.Doing it that way would mean that if the shed trips it will trip the house aswell as the RCD is protecting downstairs sockets as well
There was a guide to exporting PME to outbuildings on here at one point, It was a good starting point to answer your questions.
Basically, If you have no metallic services or structural steel in the shed then there is no need to seperate the earthing arrangments.
There's no guarantee that the RCD in the house won't trip before the one in the shed, it's more than likely will trip the house first due to the influence of other circuits.
Is this a DIY job by any chance?
some people put a tt stake for out buildings but as stated you can export the earth from the main consumer unit but with a fault in the shed your likely to knock out the indoor consumer unit !! if you stake it do not conect the earth from the supply cable !! sleeve it up and terminate it into a block ,but make sure the supply earth is still conected indoors and 2 rcd,s rated the same in line is a no no unless the one indoors is a delayed one
What size cable are u using, what type of cable are you using. How far away is shed what's the In going to be......
Wonder if this is another post where we get no input from the op
Reply to Shed wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
