Discuss Side Cutters or cable Shears in the Electrical Tools and Products area at ElectriciansForums.net
Side cutters or Shears
  • Side Cutters
    Votes: 10 71.4%
  • Shears
    Votes: 4 28.6%
  • Total voters
I also got one of the side-cutters with a gap for 1.5mm and 2.5mm cable and find it is a pain as often it fails to cut as expected due to the gap (e.g. on cable ties, etc). So looked like a good idea, in practice not so handy.
Agree, I had a c.k pair with the 1.5 and 2.5 notches and as much as I wanted to like them I simply couldn't get on with them and just went back to a normal side cutters
I quite like my CK cutters with the notches, neat and light in the pocket, and their shears for larger cables. The Knipex installation pliers are a good all-rounder but not a universal "fix" in every situation, and the crimping function is not something I use, preferring proper ratcheting ones for that task. For T&E the automatic strippers are ideal, except for working in back-boxes. Horses for course, I guess...
For cable-ties I trim them with carpenters pincers which are also ideal for removing Linian clips.
Mine are useful, just not sure I would ever buy a replacement. Would go for conventional cutters instead.
I really want to like them, but do so less and less as time passes.
On the plus side, they're excellent cutters in every other regard and will be replaced with another pair of 180mm CKs. I find that insulation gets in the way of my fingers on most other brands and with anything smaller.
What do you mean? Can't visualise this lol.
I hated side cutters, but i've grown to love mine.
I find the insulation gets in the way of my finger up near the pivot on many side cutters and combi pliers - not sure how to describe it myself, but I keep a finger between handles to flick them open and with some brands there doesn't seem to be enough space in there. I think it's down to how handles curve out from the pivot.
you neeed to buy a pairofKim Kardashian ones. they are more curvy.
Reply to Side Cutters or cable Shears in the Electrical Tools and Products area at ElectriciansForums.net
Hey guys . Just recently purchased some klein cable cutters and the packaging states it cuts and strips upto 9mm but it can easily go through 25mm...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
So I have always been a side cutter guy for cutting & stripping cable BUT I see a lot of folk using cable shears (Like The ck 3963) for cutting &...
6K
Electrical2Go - Save Time Installing Cables with Super Rod At Electrical2Go, we're constantly striving to bring you the latest and most...
