Discuss socket in 1.5 in the Australia area at ElectriciansForums.net
Depends on your cable installation method ... best to stick to 2.5mm with a 16A breaker if you have to wire it as a radial. Circuits only ever get extended & their loadings increased ... usually by kitchen fitters, plumbers, carpenters, bodgers etc so atleast your starting from a decent point.
1.5mm cable, 10A MCB ( or a very thin nail ). label socket " DVR only "
Without looking in the BGB/BRB i would say yes, normally a 1.5 twin can carry 19amps
Putting it on a 16a breaker will stop any equipment being plugged in that will overload it and DAMAGE the cable
however as good practice i always use 2.5 twin for most socket outlet work, the odd occasion requires 4mm
all depends on what bits are on the van. a 5m length of red/black from a strip-out comes in handy
Reply to socket in 1.5 in the Australia area at ElectriciansForums.net
hi....im running cable for a split type 1.5 hp aircon....i have a roll of english 2.5 twin & earth, is this ok for the job? im running it to the...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
