Discuss Solar CT installation in the UK Electrical Forum area at ElectriciansForums.net
Sparks101
Afternoon guys,
I have a solar installation. The panels and Fox ESS hybrid inverter, Fox Cube batteries, are all installed in the garage. They feed into a mini consumer unit in that building. This in turn is wired, via armoured cable, into it's own MCB in the main house consumer box.
I am required to install a CT clamp, however they suggest that this needs to be in the main house tail. I don't want to trail a wire, either under or over ground.
is there a way around this? The CT is for the DNO, however the Fox app also takes information from it.
Cheers
Afternoon guys,
Cheers
Alright,
Only option would be to install a wireless transmitter at bother ends. The ones I've used before with Giv and Growatt systems are made by Owen Brothers.
Reply to Solar CT installation in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
We recently had a solar panel system put it in. The solar batteries were delayed and put in after, at which point it became clear that the CT...
13K
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
