Discuss Spur ext socket in the UK Electrical Forum area at ElectriciansForums.net
Hello im new here, trainee electrician
To the point...
power in the shed...
The closest supply to spur of is an external socket..i cannot run a new feed from the cu as the house floor is tiled.
My plan was to spur of the external socket using 2.5 armoured cable...take it to a 13a fused spur in the shed and another down rated 6a spur for the lighting?
Is this a good plan? Any alternative suggestions?
To the point...
Hi Riko,
As a trainee, I assume you have access to an On Site Guide and a copy of BS7671. Rather than directly answer your question, I'm going to refer you to Appendix 15 of BS7671, which you can find on p505. Have a read through it, then come back and tell us if you think what you have proposed is correct or not, and why. Then we will do our best to guide you.
Reply to Spur ext socket in the UK Electrical Forum area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Hi, I have recently moved house and what to replace the garden shed. The shed has some electrics; a double socket with a fused light switch and a...
