Discuss Testing fixed appliances in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
P
peehead
Hi all,
i've been asked to test a number of fixed appliances in a flat and haven't has any experience with these yet. I'm wondering do I just disconnect them from the wall and using my fluke 1651 multi meter do insulation and continuity tests at the flex going into the appliance or would you test from the CU just to cover that circuit.
You have to do it at the appliance:
1, Functional test then isolate.
2, Cable and appliance visual condition check.
3, Fuse rating.
4, Security of connections to the supply and correct polarity.
5, Check means of isolation from the supply eg: FCU
Then do your checks
Recommend another quick function check after the testing to see if anything has screwed up. If you check basic function before and after, they can't claim "it was working before you put that machine on it"
Finally record results and sticker it.
ps: The 60p/label Cowboys just do the recording and sticker operations!!!!
You could Use a r1r2 plug tester along with your fluke leads also just to highlight if you are a spark you can test at the fcu if not then you are not insured.
Yes I know but welcome to the world of ISITEE
r1r2 plug tester plugged into PAT m/c, 3 leads from r1r2 plug to ends of disconnected flex in FCU, probe/croc clip attached to appliance, hit the go button. Don't forget safe isolation procedure before removing FCU from wall :)
I've no idea at all, I'm having a real blonde moment. With the r1r2 plug there is know here to plug it into. Is there any videos or pics out there of the test process.
I had a play with my micro and just had to stop as I had no idea. My mate has my book at no as he's studying for his pat testing course hence I'm in the dark.
Continuity test.
Turn fluke 1651 to continuity test. One croc clip on earth pin and other in Line
Insulation test I can't get for some reason. I'm missing something but not sure what
All help is good
Reply to Testing fixed appliances in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
