Discuss Tightening locknuts with hammer and screwdriver-dog rough or not? in the Electrical Engineering Chat area at ElectriciansForums.net
Stretch the job out.
Disconnect and remove any other glands that are blocking using the proper wrench, then reconnect. Turns a half day job into 3 full.
I’m sure no one would batter an MI gland the same way.
I certainly wouldn't pummel an MI gland with a hammer and chisel , not unless you want to spend the next hour re-making it all off again
That's the answer. Shut down half a building, then spend the rest of the year looking for new work in the few moments of respite between insurance claims.
The problem seems to be that most on here are saying, because of space restraints they can't get a tool on the nut to tighten it. I can't think that any manufacturer would put a unit on the market that is so badly designed the knock outs are too close together to allow tightening of the locknuts with a tool.
Knockouts?
Usually the problem is too many outgoing single phase circuits and no space to use other parts of the board. Sometimes it's down to lack of foresight from a previous spark who felt their life would be easier if they kept all outgoing cables to the front.
When I've previously commented about lack of space to get a tool in, it wasn't a flippant comment. Thankfully this isn't an everyday occurrence for me, but in my couple of short years in the industry it's something I've faced on a number of occasions.
What insurance claims?
Maybe the one about working in a board with live circuits?
You would have the board shut down of course? …. wrestling a big cable and gland into its hole, swinging a big hammer around and all that. Whoops, slipped, bang!
That’s the crux of this thread though…. Saving time by using the wrong tools, and basically cutting corners… because, “ if you don’t do it, someone else will”
Now where have I heard that before?
You've got to admit, removing several armoured glands just so you don't have to spend 30 seconds hitting a locknut with a hammer and chisel is a bit OTT. There's doing it properly but there's a phrase 'where reasonably practicable' that is used a lot and this is one of those times. Spending 3 days, 3 days of factory/unit/home downtime, and thousands of pounds, just to avoid saying you cut a corner on a forum, falls under reasonably practicable. It's not. So you shouldn't do it.
When you gland with a hammer and chisel literally nobody but people online cares. Someone on site will call you rough then you go on about your life because it makes no difference.
I'll play the devil's advocate, learnt it that way, always done it and crucially that contact point needs to be as tight as can be given in a fault it could be 1000+ amps, used every tool in the book and never been able to nip it up as tight as a thelmic planner and a old flat bladed screwdriver.
Reply to Tightening locknuts with hammer and screwdriver-dog rough or not? in the Electrical Engineering Chat area at ElectriciansForums.net
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
Hello all I'm doing a Job in France for my company where we are installing SWA for power to our own control panels The issue is the DB is a...
9K
Silly Sausage
S
