Discuss Timber Frame Extension in the UK Electrical Forum area at ElectriciansForums.net
Hi guys
After some suggestions. My next job will be to wire a new timber frame extension throughout.
My questions are any tips for running cables down outside of beams to sockets and also thinking about using oval conduit within walls containing insulation boards.
Any tips much appreciated.
Do you mean running cables for sockets down exposed beams?
I can’t see any issues with oval conduit in insulated walls as long as cables rated accordingly. Might be simpler to just clip to stud work though.
Hi Tim
Thanks for the reply.
Yes down exposed beams. Obviously it needs to look the part.
The cables basically need to be up a size within cavities due to heat exposure I believe. I plan to reduce the load on each ring etc
Well for exposed beams the first decision is whether to try and hide cables or not.
Routing out a channel and capping is an option.
Making wooden trunking is another option.
On surface galv conduit can look good depending on aesthetics of rest of it, as can MICC for a price!
There’s also flexishield which holds its shape well and can be neatly P clipped.
The cheapest and easiest is wood effect D line trunking from TLC, that looks pretty good and solves the problem with minimal effort.
You can get wood effect boxes and even sockets.
All depends on time and money!
Thank you so much for all your help.
The alternative is to go coloured conduit and highlight its position with coloured surface box's and switch/socket plates, can look very effective in the right environment, red in an office, blue in a bedroom etc:
Reply to Timber Frame Extension in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Im running a ring main for all my sockets using 2.5 cable....as an after thought i was thinking to spur off one of my socket outlets and run up...
