Discuss Timer control of outdoor socket in the UK Electrical Forum area at ElectriciansForums.net
Is it ok to control an outdoor double socket with a programmable switched timer - the type usually used for lighting? The sockets are for a pond pump and filter which use c 35w while the timer switch wd be mounted in a shed and on a 6a mcb. My sparky didn’t sound concerned - he basically said buy in the stuff and he’ll come and fit it. The pump is well within the max load of the switch but my understanding wavers when I see that the min varies on the lighting used. And I can’t find any web evidence of this kind of set up. So any thoughts gratefully received.
Plenty of time switches available that are rated at 16A.
There's a big difference in the rating of a given switch between when connected to a resistive load (lights) and an inductive load (motor).
Bg do a cheap and nasty outdoor timer socket. Got one myself for Xmas lights 2 years ago, and it really is cheap and nasty, but functional. (For now)
Reply to Timer control of outdoor socket in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Our electrician inexplicably wired outdoor floodlights attached to side of house over driveway as "always hot", no switch. We don't want them...
Hi, I am a basic DIY'er, with basic electrical skills, NB, I can change a plug/fuse, change a ceiling light fitting, change a socket face plate...
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
Hi All, Appreciate some advice on an outdoor socket and lighting circuit please. I currently have an outdoor socket on my house, that i believe...
