Discuss Traying a swa round a corner in the UK Electrical Forum area at ElectriciansForums.net
Can't understand why to keep it uniform the tray wasn't taken away from the wall pre bend then you go around the bend and take it back so it matches both sides.
Bit of a bodge methinks.........
And the radius isn't uniform around the bend, tsk, when I where a lad.............
Reply to Traying a swa round a corner in the UK Electrical Forum area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Rewiring an old farm cottage… every wall brick and previous wiring not done well at all. I can’t locate any of the prescribed zones diagrams on...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
I was the 2nd sparks taking over a garden office supply job. The first sparks had fitted 10 sq mm 3 core SWA, but it actually had brown, blue and...
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
