Discuss TT and RCD Protection in the UK Electrical Forum area at ElectriciansForums.net
T
thomas-1981
I was doing work on an commercial site today. The supply is TT and the install is about 25 years old. I was under the impression a TT system had to be RCD protected to meet disconnection times. But this install only had a few circuits with RCBO's. Would the version of regs the install was designed to not require RCD protection? Thanks
around that time it was usual to fit an up front 100mA RCD on a TT system. if you are doing any work in it, i'd be inclined to fit a new CU with 100mA delay RCD as main switch and 30mA RCD/RCBOs for all circuits.
If it had RCBO,s this would give you your RCD protection would it not ?, unless you meant MCBs ?
"Shall we eat grandma?"
"Shall we eat, grandma?"
Big difference. ;)
One day... One day, I will have summat useful to contribute other than inanities.
What was the Ra?
Its been 22 minutes since your post. Did you eat Grandma??
Om nom nom... :)
Reply to TT and RCD Protection in the UK Electrical Forum area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
