Discuss Underfloor Heat Mat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
T
TPES
What do you think to this..
I have been asked to install underfloor heating in a new built ensuite bathroom, The builder has had to put a number of layers down on the floor like a thick insulation board and has then laid chipboard flooring down.
I have been told i cant raise the floor up with yet another insualting board as the floor level is already at a stupid height and me adding to it and then with tiles ontop is out of the question.
So basically what are your thoughts on laying a 150w 2.5m2 heatmat onto chipboard? as i cant raise this floor level anymore would you be happy to do this?
no would be the answer, chipboard is not much use with heated floors
I have found it only works well on tiles or solid wood laminate to about 12,5 mmm
also how is the chipboard secured?
if you lift the chipboard to fit the mats how will you secure it without damaging the mats!
i wont lift the chipboard, the heat mat will lay ontop of it, then the tiles. theres already a huge amount of insulation under the chipboard, i was just abit concerned about the heat directly on the chipboard..
am i worrying for nothing and it will be fine?
I actually think the tiler is mad for tiling onto chipboard. I just got to lay the mat
Reply to Underfloor Heat Mat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Hi guys wonder if you can help. Just laid some electric underfloor(not going to connect it myself) it’s the loose lay stuff thin stuff. I spaced...
I went to look at mess this morning. S plan heating system, google nest heat link in airing cupboard. Downstairs in utility room the kitchen...
Hello, The floor boarding has been stuck down with adhesive and screwed down also with extra metal washers. Someone has now told me it is not a...
Conversation developed with a middle aged lady who has recently lost her husband. Note to self, stop walking dog around the graveyard Anyway...
