Discuss underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
Not purchased yet but I've been looking at warmup, the new pro kit I think it's called. Nice looking thermostats and looks easy enough to Install. Lots of videos on the net. With insulation boards stat and 6m2 kit it's roughly £650. Only topps tiles sell this so no competition for getting the price down.
I installed one last year , chipboard floor underneath and laminate floor above , I cant remember the name of the system off hand , but you have to install an insulating board on the wooden floor that comes with the kit , and a probe stat also , , the wholesaler I went to had the kit designed by the manufacturer , I would be make sure the wooden floor is stable in your case as the grout and tile adhesive may loosen , but I'm sure if you go to a wholesaler you would get the same result
I personally don't see the need for insulation boards as wood is a fairly good insulator, the ditra matting made by a German company called schulter ( sorry if spelling not correct) does 3 things 1 st and most important it provides a de coupling membrane between the unstable wood and the tile as wood will expand and contact with change in temp/humidity. It also can be part of a waterproofing system and provides good impact resistance helps tile when you drop things in it. Google or u tube it, can pick it up online from tile fix direct. There are other brads out there for example g mat but I think this one is the best.
Reply to underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
