Discuss Using appliances from USA on a 110v transformer in the UK Electrical Forum area at ElectriciansForums.net
T
Toneyz
Got asked today by someone one site regarding a friend who has come over from America and wanted to know if he could use his appliances /equipment in a 110v site transformer110v 55v to earth.Couldn't give him an exact answer as unsure , can anyone give me an answer.
Just play the Star Spangled Banner before you switch it on it'll be OK, then shout very loudly USA USA should be alright. usually is
If they are OK on 50Hz, then they will generally work correctly regardless of whether the supply is 110V with an earthed neutral, or 55-0-55 CT-E. However, there may be minor safety issues if they are equipped with a grounded or non-reversible cord that is intended to correctly identify line (hot) and neutral in the appliance (some US appliances have reversible 2-prong plugs where L & N could be either way round). In this case there is a possibility that single-pole fusing and/or switching is used that is supposed to be in the line conductor. With 55-0-55 both live conductors are lines, so a single-pole switch will no longer isolate the appliance and an internal SP fuse will not protect part of it against earth faults. Therefore, it is theoretically better to operate US equipment with an earthed neutral 110V supply, not 55-0-55 CT-E. Most transformers supplied with a US style outlet (NEMA 5-15 or 5-20) will have the supply neutral correctly connected through to the output (they are normally autotransformers) and these can be bought in all sizes.
Items that might not be happy on 50Hz would be those with induction motors (large appliances especially) which will run slow and hot, and large transformers which may also run a little warm, or hum more, or have more serious inrush.
Reply to Using appliances from USA on a 110v transformer in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
I'm working on a site in the UK where a joinery company will be installing bespoke vanity cabinets. The cabinets will have MDF/mirrored doors with...
