Discuss Wap ceiling boost pain in the axxe in the Home Media Centre Forum area at ElectriciansForums.net
i'll check it with a clamp meter when i can be arsed to re-open the socket. won't be more than a fraction of 1amp.
In answer to your question @telectrix , no I haven't. I was looking at them for the couple I'm doing some work for at the mo as they have WiFi issues... stone house, quite long from front to back.
So... I'd like to know how you get on with it :)
seems to be quite good. wi-fi signal at front of house is much better than before. from weak to good.
Thanks mate , are you saying if I get a poe switch I can run the wap of my existing WiFi ? I have exactly same wap as your link but struggling to set it up ! I’ve hard wired it back to my virgin internet ?
You don't need a POE switch as you can use a POE injector. Shame as I had a few and gave them away a while back.
Your Virgin Router won't be able to power the unit so cable to POE injector then cable from POE injector to the WAP, did it come with a POE convertor at all as they used to but then stopped to save on £££'s
If you need any help PM me and I will give you my number/email addy.
Ubiquiti PoE-48 PoE Adapter (POE-48-24W-G) - https://www.4gon.co.uk/ubiquiti-poe48-poe-adapter-poe4824wg-p-6457.html?gclid=Cj0KCQjw3KzdBRDWARIsAIJ8TMTZWBldZwMQWphcjyfTM6S2hc8KKD2yGHXqmgQ2RUgZq-nEvUk8w9gaArEwEALw_wcB
Thanks for your help mate ! Let you know how I get on
Reply to Wap ceiling boost pain in the axxe in the Home Media Centre Forum area at ElectriciansForums.net
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
