Discuss Welder transformer zapped in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Hi all I need a bit of help from the wise wizards I mate has a heavy duty mig welder which gave up the ghost on him I have had it apart the transformer that supplies 24vDC has no continuity through the primary and on close inspection the "in" if you like has detached itself from the terminal pin, I have tried to source one from Kemppi direct but it takes over a week just to place an order, now at 230V AC primary and 24 V DC secondary I can source one of a generic nature but how important is the VA there is no indication on the tranny and the data plate is to me anyway confusing as there is no direct ref to the 24V tranny this plays no part in the actual welding process it just supplies the contactor A1 A2 coil direct its a Kemppi 9777803
TA
if it's just feeding a contactor coil the amps will be minimal
If you can see the detached end of the primary winding it might be fixable. If you need to insulate the joint, you'll want to solder to the winding first, then slide on the sleeving, then solder to the pin. Use a heat shunt to prevent the winding desoldering. If it has adequate clearance to remain bare then you can solder to the pin first, which will support the joint and won't desolder while you connect to the winding. Many winding wires are self-fluxing but don't breathe the fumes.
If searching for a replacement, many PCB-mount and chassis-mount transformers are pretty interchangeable. If the DC supply voltage is 24V and there is no regulator, the transformer secondary will be about 18V AC. Pics would help.
its a 230v ac supply with 24vdc output I have ordered one from CPC as a trial for £18 the oem is £90
Reply to Welder transformer zapped in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hi, I want to have installed 2 x 16A commando sockets in my shed. I want to run a MIG welder which has a max output of 180A @ 23V and a 3hp 2.2kW...
5K
