- Reaction score
- 5,607
What are the dangers of poor insulation resistance results (i.e <1Mohm) between neutral and earth?
If all other tests are ok, what are the dangers of the above?
My thoughts are it may indicate a breakdown of the insulation somewhere. However, what are the dangers of this breakdown between neutral and earth? They are both at the same potential already.
What are the other dangers? Is there a risk of fire somehow with poor N-E readings? I can't see how (if all other tests are ok). Although, perhaps the poor IR results are due to a poor connection which is heating up the cable, causing the insulation to breakdown.... so perhaps fire is a possibility?
