Discuss what connection to make for the fan switched live wire in a fcu in the UK Electrical Forum area at ElectriciansForums.net
lestati
can anyone help with the connection for the switched live from the bathroom fan in this fuse box. it is the unconnected yellow wire with a red sleeve and i assume it goes into the top right OUT connection with the single red wire. Thanks in advance
no way of teling over internet. needs site visit with test gear to determine which conductor does what. it looks a mess and will probably need some reconfigurations, maybe a 3 pole isolator, and critically circuit needs to be RCD protected, and fan manufacturer's instructions followed, e.g. 3A fusing.
That is one of those "Where to start" without being overly negative pictures.
There are a lot of coulds but only one should.
As with the two statements above we could guess but that is not how we like to operate, key here is your safety. From a distance it is impossible to say for sure where it belongs. As in #2 it is a mess and your best option is to seek on site professional help.
I like it. No one's jumped in with a presumptuous opinion.
As with the above's.....pro's help.
thanks for the information. it has a 3a fuse in the box and it is protected at the box in the garage. i think the electrician who wired it in 20 years ago fed the switched live into the fuse box and just cut it off instead of connecting it. think i'll have to get an electrician around.
That is definitely the best option. Let us know the outcome would be good to know.
maybe if you posted your location, one of us maybe close. a forum discount on the cost might be applied. :):):)
Reply to what connection to make for the fan switched live wire in a fcu in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
