Discuss What is it with house bashers racing to get a board done in the UK Electrical Forum area at ElectriciansForums.net
Another ‘let’s see how fast I can go’ board change ...
testing ?
I hate having time pressure on a board change - sure it can be done quickly if testing has already been done (which is how I normally play it), but I'm much happier taking my time alone in the property with no encouragement to rush things just to get a light or the kettle back on...
i use a small 4V driver with torque settings. then tighten by hand. usually less than 1/4 turn to get then right.
I had a tiny battery drill made by ‘Sparky’ iirc , for doing fuse boards
it got stolen on site one day , along with my Skil 18v drill and I never bothered to replace them
Once started a self employed spark and found him using one on a new 3 phase Schneider board....... down the road before he'd finished it.
It's all come about with circuit breakers, though. With old DB's it wouldn't have been worth it.
I would not use an impact drill on any electrical installation, but have used a Hitachi electric screwdriver set at a low torque and final tightened with hand held terminal driver.
I found a few of the MCBs come apart worryingly if you tighten them too hard, particularly at the top terminal - so not sure I'd ever risk a driver on them - though as always its important to use the right tool and not be one...
Reply to What is it with house bashers racing to get a board done in the UK Electrical Forum area at ElectriciansForums.net
Evening all, I'm relatively new to the trade and have just moved house. Looking to rewire and was looking at a few things, could someone tell me...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
