Discuss What is the age of fuse box. in the UK Electrical Forum area at ElectriciansForums.net
Skiplndn
What is the age of General Fuse box No,723607 Class-CTL???
I suspect the important answer is "too old for continued use".
I am not from your side of the pond but to hazard a guess I would say 1960-70s, and the chances of it still having safe replacement parts are slim. Quite probably if fails on other aspects of the latest code, but see if one of the USA members such as @Megawatt appears as he will know far more then I do on this.
What is the age of General Fuse box No,723607 Class-CTL???View attachment 105878
That old Edison base fuse box is probably older than you are. If I ran into that I would upgrade the service to 200 amp and gut the old fuse box and make it a junction box and just make splices pulled from the main. Right now all you have is 60 amps.
General Switch does not exist anymore either, last time I saw their brand for sale is when I stopped in a home center in Texas in early 2000 & saw their panels being on clearance. That fusible panel is old, by the late 1970's fusible panels were removed from the manufacturers catalogs
Reply to What is the age of fuse box. in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
Hi ive recently got myself a mig welder for my garage but each time i try to use it it trips out. Ive spoken to an electrician and he said its...
