Discuss WHAT IS THIS? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Brunel
This is connected into the C.U. supply from D.N.O. fuse.
There is a Solar feed in, also on the premises.
1. What does this actually do, besides the obvious.
2. Is it actually necessary?
it's a supposed energy saver. reduces your supply volts to 220V. waste of space. kettle takes less leccy per minute, , but takes longer to boil at lower voltage, but consumes exactly the same amount of energy to hot the water. the only saving you get is with standard (tungsten) lights, but they will be dimmer.
This could be one of the rare occasions that the device in question is actually useful.
if your supply voltage is on the high side of the allowed tolerance band, the solar inverter is not able to “push” electricity back to the grid.
by lowering the voltage inside the property, it would allow the solar system to supply energy to the equipment inside the house.
Reply to WHAT IS THIS? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi, firstly appologies if my terminology is wrong but I know very little about electrics and have no idea why this is happening - I have 2...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
