Discuss White Flexi-Conduit, in the Electrical Tools and Products area at ElectriciansForums.net
Dustydazzler
Supporter
Anyone know if any of the big wholesalers stock White flexible conduit ?
I have a customer where I was going to use black flexi But now they want White
CEF in Swindon had loads of it on a high shelf at the back of the store, that they didn't know was there, nor appeared on any stock list or computer. Had to negotiate a (small) price to get a coil.
Was about thirty years ago, but you never know......
2.5kM of flexi conduit? Could you not do at least some if that in rigid conduit?
Normally come in 10mtr packs from the DIY shops like Screwfix and Toolstation , I probably need around 250mts
There is a lot of application where it comes down a wall say then straight under soils and pops up mid planter or bed. It will be easier to keep it continuous in Flex rather than cutting , bending and joining straight conduit
Reply to White Flexi-Conduit, in the Electrical Tools and Products area at ElectriciansForums.net
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
Looking to fit a USB-C PD wall socket for charging / using a laptop - so I was hoping to find one that supported 90W or higher charging, though...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
