Discuss why so many wires just for a light? in the DIY Electrical Advice area at ElectriciansForums.net
hi, im hoping someone can shed some light..(haha get it ) on this for me. i only wanted to change the white switch to something a bit more colourful but wish i hadn't started and would like to just put it back to how it was. but there seems to many wires to do so. theres 5 groups all seem to have 2 wires per sleeve, ive got them all mixed up and now half the lights in the house dont work. the switch is for the downstairs hall,and also works the upstairs landing, upstairs there is only 1 switch and that works the upstairs landing. (well they did until i come along) also i cant remember what one of theses switches was the original one.. please any info is greatly received.
Unfortunately once they have been disconnected it is not possible from a distance to tell which wire does what.
It is always a good idea to take a picture of the original setup so that you can restore it if required.
All the uncovered copper wires should be sleeved green and yellow (as some of them are) and connected into the terminal on the top right of the silver back box.
The cable with two red cores (as well as the earth) on the right is probably going between this switch and the landing switch.
Other than that it does seem as if you may have one more cable than necessary in some situations but could be normal in others, but no way to tell without testing.
The lower switch in your picture would have been the original because the upper switch still has one of the fixing screws in the delivery position in the plate, however both switches do the same job, the terminal layout is just physically different.
It's worth adding to the photograph it suggestion, mark the cables (I use a Sharpie and just ring them, 1 ring, 2 rings etc.) before photographing.
And I would have whole heartedly shared Richard's view about which switch is new for the exact same reason, but I have just recently done a job where about 50% of the fittings already in place still had their screws in the delivery positions.
Reply to why so many wires just for a light? in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
