- Oct 30, 2021
- 12
- 2
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Heavily Qualified Electrician / Teacher / Tutor - etc
Hi guys,
Is there a standard tolerance percentage that should be followed when checking the winding resistance of each coil on a three phase electrical motor?
The general rule of thumb I followed when measuring winding resistance was that each phase winding had to be identical or close to identical, the resistance would
vary on each motor due to the cross sectional area of the winding.
I've searched the web and there is varying opinions from +/- 5% and +/- 10%.
I just want to know what your thoughts are? The IEC to my knowledge haven't posted anything regarding this.
Thanks,
Ewan
Thanks,
Ewan
