Discuss Overloads? in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Is this the overloads
No, those are lords who have subfeudated an estate or manor to a tenant. Oh, wait...
Overload relays, yes of course they are. Clues include manual/auto reset, current dial, terminal numbers, part numbers.
Yes, standard motor overloads, I can guess if this is to regulations that the coil voltage is DC and highly likely to be 24v DC... Lucien will know where I'm coming from.
DC control when working to En60204 should be dark blue.
LOL missed the big 24v DC on the white just going by the blue code wires, the dark blue only applies if you have a blue Neutral as to distinguish between any N wires and 24v DC although adequate marking can be used but like you say its prefered there is a difference between the actual shades of N and 24v DC...... but im probably teaching you to suck eggs here :wink5:
I would suggest the builder of this panel is clued up about how to design controls and circuits but is lacking in knowledge of the BS60204 as they have cherry picked certain reg's and totally ignored others, also I would suggest a PLC would have simplified this set-up greatly.
Programmable relay like a LOGO sure, a full on PLC would be hugely overkill for this.
Looking at the age of the components would suggest it pre dates things like the LOGO, weren't as cheep or common as they are now.
We still design panels like this, simply at the clients request as the know their maintenance staff could maintain it if it broke down.
Do vsd's take in single phase and spit out 3ph
Vsds can be single phase in or 3 phase in. All output 3 phase. They output the same voltage as they are inputted (no doubt there will be exceptions but none that I have seen) ie 230v in single phase = 230v 3 phase out.
400v 3 phase in = 400v 3 phase out.
You can get single phase output for 1ph motors, they are not just for 3ph motors.
You can get step up drives e.g. 110v in to 220v out but these are limited to the very low HP range.
Not as common I'll give you that but it does mean what you have put is incorrect :hair:
Panel obviously does not meet the requirements of the Machinery, nor Low Voltage Directives, again.
This is becoming a very common theme these days, why I wonder is it that there seems to be an increasing number of panel & machine builders who can't design a panel that complies with statute law?
I think the short answer is probably the same reason there are Cowboys in every trade, because nobody has stopped them and people keep paying them.
Sent from my iPad using Tapatalk
It may not be compliant with the machine regs but I regularly come across panels a lot worse than that. Just out of interest what's the component that's mounted at the front right of the base of the enclosure?
It's hard to tell but I be guessing at a panel heater to stop condensation :hair:
FFI?
Fees For Intervention.
Levied on companies that have a material breach of statute law.
Hopefully these will start to hit home and companies will begin to learn that they need to comply, because not only will they get a PN or an IN, but they will get FFI too, that will cost them out of their bottom line, and they can't insure against enforcement.
It is I think £129/hour currently.
I've seen worse like this work of Art.
That's not bad for an old panel.
I've seen & worked on MUCH worse.
However, the statute law is there and it controls new panels.
Hopefully the legislators will soon catch up with the rogue panel builders and buyers and put them out of business, so that those that do it right are competing on a level playing field.
It sounds like a good move, but still suffers from the relevant authority needing to find out about the problems in the first place
What are the requirements that it doesn't meet?.
Sent from my E5823 using Tapatalk
I can see a few what I would class as cosmetic breaches of the BS60204, I would need more info on what this panel does and controls to know if more significant regulations have been ignored, it is usually the case when someone builds a panel and cannot get the basics right like colour coding and marking of cables correct that they will be a high probability that the panel falls far short of requirement.
I agree darkwood, just wondering what netblindpaul has seen which doesn't comply with the statue laws he mentions.
Although is the colour really a non compliance with BS60204 as numbers are used? Colours or labels or mixture can be used as I interpret it. What's your thoughts?.
What marking of cables do you see wrong?.
I'm not disagreeing with you here just discussing what issues can be seen.
Blue - DC control
Red - AC control
Black -AC or DC Power circuits
If a N is present then the control DC would be blue and the N an unsaturated (light) blue, as I see it, if they are clearly marked then it can be negated but markers are often lost or illegible over time so the preference is to ensure they are visually identifiable.
I would need more info but I don't see a mains power contactor, isolating TX which may be required but as N conductors are used within the panel then design has to take into account the loss of a N and floating voltages been raised from 230v to 400v thus avoiding this damage to equipment needs to be implemented into design if this issue occured.
Cable colours can be deviated from 60401 if identification is used.
Or if is a particular site standard. I know the water board round here have there own specification that must be followed.
Reply to Overloads? in the UK Electrical Forum area at ElectriciansForums.net
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
Anyone know of an RCBO manufacturer, apart from Chint,that includes an indicator in the RCBO to indicate if the trip is a earth fault or an overload.
an overload current is classified as an overcurrent occuring in a circuit which is electrically sound has a fault between phase conductors has...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hi all I just picked up an older 36 volt golf cart The speed controller is a curtis 36volt 350 amp I was wondering is there a way of protecting...
