Discuss Green black Green grey Cable in the UK Electrical Forum area at ElectriciansForums.net
C
CRAGS
Anybody ever coma across this just started rewire there is green black and green grey cable only quickly had a look so not had chance see where its going or coming from or what its connected to in the consumer unit ???
I'm not being cheeky but I can't for the life of me decipher what you mean by green black and green grey. Could you explain it a little better please?
Hi bud,your pre-DB fit tests,will identify this circuit,and maybe,the suitability of continued use of this cable.
Be nice to hear what it was :)
Could be singles plus cpc used this type yonks ago, but the cpc was not insulated it was inside the grey sheath, bet its the lighting circuit
Intially my thoughts as well lighting circuit and cpc also thought it could have been to do with 2 way lighting but I have ruled that one out will double check today it looks like it is coming up from the board like that
Yip it'll be lighting, I saw this quite often in a certain area whilst testing local authority houses. In that case though it was only both live cables run in singles without CPC. They'll be aluminium core or coated copper also I'll bet.
Extra could be exactly what you say "phase colours" but remember sometimes the Black and Grey were the outer sheathing colours (as in twin and earth" I still can recall wiring houses back in the 70s with exactly that type of cable, your call was a good one though, the more I think about it the more I think my theory is the right one, can the OP open up the CU or wherever these cables go and get the answer? the plot thickens, where is Poirot when you need him?
Could be wide of mark because I have never seen mains cables with a coloured stripe on them, I have with speaker cables though?
Could be right about the black single West but the grey? I'm sure that green showing is a cpc insulated, lets hope the OP comes back with more detail, otherwise it's pure speculation.
Been looking at this on and off all day, if you can enlarge his first picture the green on the grey cable is a stripe, it doesn't cover it all. When did green become green/yellow because he says it dates to 1977. Speaker wires have a stripe down one side to identify the cores because they are bare beneath the sheath, mains wiring is not apart from the bare cpc.
How would that score on an EICR with the separates not being contained with a CPC for the length of its run? Obviously T+E support the regulation but this would not.
Had a look today it's all coming out and been rewired it looks like it's cpc and single but didn't investigate to much as it was coming out anyway and it was to the lighting
Lighting in my house is wired in single sheathed cables, but as has been said above it is normally grey sheath with a red or a black inside it, and possibly a CPC. Never seen this stripy stuff. Do let us know what it was connect to!
Daz
The OP also mentions "quite a few reds about as well" I agree with PEG the CU would confirm or not whether the cable are what some of us think they are, you also need to take Westy's comment about never seeing mains cables with a green stripe running through them, a good spot, this was posted last Friday, you would have thought the OP would have come back to us by now. May be he has lost interest, as I am , gradually, come on OP open up.
Sorry for the late reply been really busy on this not really got down to the route of it as the cosumer unit is a bit of a mess... the lights have been rewired now... it looks like the green and black are cpc but not had a close look as been pushed for time will be hopefully doing a board change within the next couple of weeks so will have a better look then
Ok guys had a good look today the green and grey was live and cpc the green and black was cpc and neutral I've never seen this before few pics to follow yes I know there's no sleeving on the earth yet
I knew it (smart arse)
I've never seen wiring like that... looks like solid copper conductors, not copper coated aluminium.
Reply to Green black Green grey Cable in the UK Electrical Forum area at ElectriciansForums.net
I have been carrying out an EICR on a property and have come across this black tarry substance on 2 of the cables. I have seen the pitch oozing...
4K
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Afternoon all. I’m doing a dorma / loft extension all circuits for that extension are new . I’m going to upgrade the consumer unit also to...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
