Discuss Fluke T110 fail self test in the Electrical Tools and Products area at ElectriciansForums.net
it wasn't reading continuity between neutral and earth or at least most of the time it wasn't.
Its failing the self test
and the "left" light keeps illuminating when im testing line to earth.
also sometimes its reading 50v rather than 240 volts on lighting circuit
if you touch the probes together its supposed to light up the continuity light and an audible confirmation that there is continuity. Sometimes it works and sometimes it dont
Well that's naff. When buying a reputable tester from the likes of fluke you expect it to out last you.Yeh, like iv said above, they've just said it's an unserviceable item and so has to be replaced
get it opened up; check soldered connections of the leads inside, and the continuity of each lead, tip to PCB.Well that's naff. When buying a reputable tester from the likes of fluke you expect it to out last you.
That's what id do... it's already flicked what more damage could you do?get it opened up; check soldered connections of the leads inside, and the continuity of each lead, tip to PCB.
Reply to Fluke T110 fail self test in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
