O
omoeko
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
Are you a Qualified electrician ?
are you registered with a trade body for Part P ?
As of 1 January 2005 it is a legal requirement for all work on fixed electrical installations in dwellings and associated buildings to comply with relevant standards. The relevant UK standard is BS 7671:2008, 'Requirements for electrical installations' (The IEE Wiring Regulations 17th Edition). BS 7671 covers requirements for design, installation, inspection, testing, verification and certification.
Best you ask for a reputable Suitably qualifed and registered contractor to carry out the installation for you, and then to provide you with the relevant certification and registration to the Local Authority
or risk electrocuting yourself or a massive fine or both
I am not doing the work myself, as i am not an electrician. Just want to ensure that the list of materials is somewhat correct, as i supply the materials to the sparkie.
Or try to get them cheaper elsewhere !
I make a small profit on my materials, I will even let you in to a secret
its 20 percent
that covers my time, my knowledge, and the fact that I often forget something, and have to pay for it myself
if you take your expensive German car in for a service, do you purchase the oil and filters, plugs, brake pads as cheaply as you can ?
Dont be so negative and quick to judge, i was given a list of materials by my sparkie and I thought it would be good to have it checked by someone else to ensure its correct etc.
Without seeing the job we cannot know if it is correct. That is for you and your electrician to work out.
If they have produced the list for you why are you asking about it on here ? Don't you trust the electrician ?
It is not negative, you do realise that the Law changed a few years ago, Corporate Manslaughter can be used to Imprison a person who kills through poor workmanship/shoddy materials, unskilled labour
if the Electrician has missed something off ( it happens) then you will have to pay for it later
You have a contract with a Sparkie, even a verbal contract is a contract in law
if he gets it wrong argue it with him
or do you think he is trying to make a few quid by getting you to provide extra materials ?
Hows that Nice German Car ? an AUDI is it ?
If that list was created by a spark then he or she isn't a very good one...
Do you have ANY idea of the knowledge of the parts and time it takes to get this all right?
Whenever somebody tries to do this to me I simply point out that for every minute/hour wasted by the parts being wrong/ not available will be changed at my normal rate.................... and I won't warranty anything that the client has supplied.....
So no, not being negative. Simply realistic.
My Motor Engineer ( he is a Proper motor engineer) had a chap in with a Skoda Octavia Diesel Estate identical to mine
Cam belt change was due, John quoted for normal service, plus cam belt, idler pulleys, tensioner, water pump, and Aux belt, plus some bolts that need replacing at the same time
Chap decided that John Knew nothing, and bought a cam belt off ebay
got a mate to fit it ( who is a mechanic, well works at quick fit)
4 weeks later spanking up the M way on Holiday
water pump seizes, strips belt
pistons hit valves, massive bang
the car had only done 35K and is now worth 100 quid for scrap
my Octavia that was always serviced using the correct parts, recently passed 200K in the hands of its new owner
I never bothers asking him what parts were needed or how much they cost
just left him to it
some people know the price of everything and the value of nothing
Don't think he would be happy with the single core cable you want to supply him with, or the 2.5 3 core and earth come to that
He won't be happy with that arrangement either.
Reactions: Specialist
Should be an interesting afternoon
What an odd thread. Can't believe the sparky needs supplying with the 25mm open grommets - presumably he keeps these as a fairly standard bit of stock??
Wiring a 5 bedroom house
omoeko,
GMES,
