Discuss Coin Meter confusion in the The Welcome Forum area at ElectriciansForums.net
One of my customers keeps a bag of old 50p just for the meter and swaps them back for reuse when he empties it. Won't pay for it to be replaced or rewired. Well it works so don't fix it.
Sorry not getting this now, please help, 2 flats one up one down, each flat has owne CU but you have a coin meter that is to feed power to a water heater to someone else’s flat, would like to no why this setup is
I believe the set up is from the eighties when the owner lived there and had a boarder.. the meter I have just found out has never been calibrated and the new owner is loath to install a meter for the immersion at a huge cost.. hence they all want it staying on my Meter.. even calibrating it seems to be a non topic.
as i said earlier, you can calibrate it, take 2 minutes.
or you explain to tenant and charge him the extra.
yes, common practise in the 60's when people had "lodgers", or houses split on the cheap. one customer I had complained she did not use 50p worth of hot water for her bath, so if she had her bath first, the other tenant benefitted. wanted me to put in a 10p meter so she could just pay 30p. very determined she was.
A
A penny pinching pensioner, sounds a bit like my mother. I would love to calibrate it.. not sure what my landlady would say though... sadly. Thanks for all the help.
Reply to Coin Meter confusion in the The Welcome Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
