G
Gringoking88
Hi all,
Was just looking for some best practices around using plastic mini trunking.
How do you guys join trunking on corners of walls that are not right angles so you can't use the normal pre made bends. I mean I've got a vertical wall and that has got a bend of about 30 degrees in in.
Every time I cut the bloody stuff I end up with a slight gap in the trunking which does not look great tbh. I was thinking of just using caulk or silicone filler but am seeing if there any tricks of the trade?
Many thanks,
M
Many thanks,
M
