Discuss Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Simple question,how would you install 2 Swa’s,they are to be clipped surface on brickwork,which will been seen,so looking for a nice finish.
Client does not want cable tray,Swa’s are 3c 6.00mm
Yea they look ok,using normal cleats,never looks right ,when clipping 2 adjacent to each other,the other way I was thinking maybe allband
What’s allband - googled but takes me to ‘All round fixing band’ and then some dude dancing on his head. (But I’ve a feeling that’s not what you had in mind!)
Here's another thought - Two Way Single Fixing Cable Cleat | Ellis Patents - https://www.ellispatents.co.uk/products/two-way-single-fixing-cable-cleat/
Aww, just saw @Leesparkykent already posted ... must be 2 votes for these then :)
o
Ok,they are for air conditioning,2 supplies needed
Why do you need 2 supplies for an A/C unit? As the supply to the ccondenser (outside unit) usually is all you need as the supply to the Evaporating (inside unit) is, in most cases fed from the condenser unit, as the inside unit, is after all only a small fan.
Thinking out of the box here,all round ,might be the answer ,plastic saddles in the 18th edition,may not be allowed,unless metal ....oh dear!!
or 16mm to first unit, then 6mm from there to 2nd.
As I have been out of the game for a while can you run a single multi core SWA feeding two units from two breakers correctly labelled and then split at a box? Or is this not possible?
Apologies for the silly question its just out of interest.
interesting... you could say that 4cores of SWA, 2 for each circuit, is similar to running 4 singles in conduit.
you could make your own little brackets from the solid all round band type stuff, not the hole type but the black solid type, it would look nice, just drilling the 2 holes in each one would be a pain lol, still give you something to do Tel
I'm amazed no one has suggested clipping one armoured and ty wrapping the other to it lol, your all scared you will get a hammering for suggesting it, were all waiting for the victim to arrive haha
Liking the coax support blocks - do they sell in this country?
Don't know about that supplier. We use a lot on mobile phone sites so our suppliers are normally Graham Smiths for that kind of stuff.
He likes the "insulation" tape look........
I really rock that look when I do it and go out... It's surprising how quickly the bar empties.... Easier to get a beer....
Yea that could be possible
It’s possible to do it, but I would question whether it is the most sensible way to do it. We quite often do it in stage lighting installs with 12 or 19 core SWA for groups of dimmer circuits going to the same location.
However for general power installation like this keeping everything separate gives complete separation should a fault occur, and makes it simpler to move one supply in the future if necessary.
If you have to produce a perfect looking run then I’d be looking at doing it in steel conduit, getting SWA to sit perfectly straight on external walls which are never perfectly straight or smooth themselves is not possible.
Did someone say Crumpet? this lass's Scarf doesn't look right lol
Reply to Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
