Discuss Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
Cleats and a chalkline.
Or Coax support blocks: Coax Support Blocks (Kits of 10) - https://asktowersupply.com/products/coax-support-blocks-kits-of-10
HorizontalCleats never look right, but Allband does??
Vertical or horizontal.
Yea these look goodHere's another thought - Two Way Single Fixing Cable Cleat | Ellis Patents - https://www.ellispatents.co.uk/products/two-way-single-fixing-cable-cleat/
Aww, just saw @Leesparkykent already posted ... must be 2 votes for these then
Ok,they are for air conditioning,2 supplies neededWhy 2 SWA's?
Why do you need 2 supplies for an A/C unit? As the supply to the ccondenser (outside unit) usually is all you need as the supply to the Evaporating (inside unit) is, in most cases fed from the condenser unit, as the inside unit, is after all only a small fan.Ok,they are for air conditioning,2 supplies needed
2 Ac units each rated at 40ampsWhy do you need 2 supplies for an A/C unit?
Ahh right 2 separate A/Cs that explains, sorry if I confused you.2 Ac units each rated at 40amps
OkAhh right 2 separate A/Cs that explains, sorry if I confused you.
interesting... you could say that 4cores of SWA, 2 for each circuit, is similar to running 4 singles in conduit.As I have been out of the game for a while can you run a single multi core SWA feeding two units from two breakers correctly labelled and then split at a box? Or is this not possible?
Apologies for the silly question its just out of interest.
good old crampets
Jeds ? Still use them sometimes.
Don't know about that supplier. We use a lot on mobile phone sites so our suppliers are normally Graham Smiths for that kind of stuff.Liking the coax support blocks - do they sell in this country?
He likes the "insulation" tape look........I question your taste in crumpet, tel.
Can’t see the point of that to be honest.or 16mm to first unit, then 6mm from there to 2nd.
Yea that could be possibleAs I have been out of the game for a while can you run a single multi core SWA feeding two units from two breakers correctly labelled and then split at a box? Or is this not possible?
I prefer a peanut smuggler to a camel toe........Did someone say Crumpet? this lass's Scarf doesn't look right lolView attachment 41831
50 metres,I’ve decided yesterday,the final 20 metres externally will be on cable tray.How long is the run.
Peadowho mentioned crumpet?
Peado
Reply to Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
