Discuss Understandable attitude? in the UK Electrical Forum area at ElectriciansForums.net
ive driven a car with no front brakes or abs, but i agree a multi meter is just a tool i use for quick continuity checks@Percyprod - you also are taking the analogy out of the context I presented it in, I made it clear that a multimeter can be used and is used as part of the testing sequence to establish certain faults or issues, the point of the analogy as explained in my later post was to show that using a multimeter alone does not prove and installation as safe, I also made the point it can in some cases do more harm than good as it can give false positives as well as a false sense of security to an untrained person, I have had enough apprentices in my days to understand how things are easily misinterpreted.
Would you do your own MOT (if you could) to save a few quid, rectify the faults you find with simple tests but due to lack of knowledge or the equipment to check that the brakes were in good condition or the ABS worked properly you didn't check them, would you then drive your family in it?
People do this blindly in there own houses daily with the electrics and put their life and their families at risk, we cannot stop this but we can educate them the best we can or at least make them aware of the dangers in not having the full tests carried out, that is why we do step in sometimes and close threads if we feel a DIYer should get professional help in and they appear to be ignoring members when this is made clear.
Using the car example, if a car has faulty brakes and steering, and you fix the brakes, it is still dangerous, but not as dangerous as having faulty brakes and steering.
if you have no brakes id suggest avoiding coastal roadsif your steering fails and you and your car go over a cliff, then it's safer with working brakes.try it sometime..
Reply to Understandable attitude? in the UK Electrical Forum area at ElectriciansForums.net
