Discuss After having an electrical rewire - certificates? in the UK Electrical Forum area at ElectriciansForums.net
H
Herbie
Hi,
After having a partial electrical rewire of a domestic property and existing electrical installation tested which certificates should I receive from the electrician and should I receive something from the council, also are they uploaded somewhere so they can be downloaded in the future?
Thanks in advance for replies :)
Electrical installation certificate with appropriate schedule of inspections and test results.
If you used an electrician who is part of a competent persons scheme then Part P notification should be done for you with a reference number. If not then you need to notify building control.
Depends on the extent of the new wiring, if new circuits have not been put in place this isn't necessarily notifiable under Part P.
Would that be where is says "Certificate reference"?
If the certificate is lost how is a replacement obtained?
There should be a Part P reference as well as a certificate reference/serial number.
If you lose a certificate then contact the installation company for a replacement, normally a small admin fee could be incurred.
Could the op give a bit more information
Do any of the new or replacement circuits go from the fuseboard, and has a new fuseboard been fitted?
As said, the certificate from the sparks. A compliance certificate via his/her scheme in the post, addressed to the 'occupier' of said property, if the sparks is in a scheme?
Normally that sort of info is agreed or stipulated in the quotation.
In my understanding of the definition of rewire, I'm referring to the broadest terms.
The Domestic Electrical Certificate I was given last week is 6 pages, there is no mention of Part P and nothing has arrived in the post.
A new consumer board was installed.
As far as I'm aware that is work that should be notified (I'm not from England so not sure). If you loose the certificate you generally can get another one from the electrician but will have to pay for it
Neighbour has just received her building cert for a garage conversion that was completed two years ago...
The 6 pages you've received... Are they hand written? Could be an indication that he has duped it and sent you a copy but not yet filed it with niceic or equiv. Or could also mean he printed a load of certs off the internet and hands them out without filing them. Who knows...
Your gonna give the OP nightmares; often there is a more simple less devious reason.
Unfortunately very real possibility though..
Replacement certificate should be easy to re send if digial, litrelly resave as PDF and email. And with Part P notifocation i always email them myself. Weather it be to the client or to myself so i can print it and hand it over myself.
Sod that. I paid my scheme £500+ a year. Thats their baby.
Cancel that, how do you email your clients with the compliance cert?
with NICEIC / Elecsa you simply put the customers email in or have it sent to yourself. in anycase you just click the notify tab and can save the pdf file of the notification/compliance certificate. then print or email it to the customer. all your past notifications are listed and you can reprint as you need to.
its far easier to notify at same time as finalising the EIC than to do it later. its only a few boxes to tick. have them all sent by email and its done.
Can you not check the Part P thing online? I seem to recall looking into it when I replaced my grandparents CU and the details of the notifiable work was listed on the website under their address. No idea what the website was though.
Yes, you can. you can type in the postcode on the niceic checkmynotification page if it was one of the certsure schemes and it was done by the books. otherwise the council building control site should have it on, although it can take several weeks to be updated as they get sent the stuff from schemes in batches.
I was with Elecsa. As far as I recall, after completing an EIC, you automatically went to & filled in the notification document. Before finalising, you were given the option of posting, or emailing the completed compliance certificate to your client, each for a small admin fee. I never emailed one to myself, as this also incurred an admin charge, as I recall.
I would save a copy of the EIC (& minor works) as a pdf file. You do not have that facility with the compliance certificate, unless you pay the admin fee. Which was my point.
Reply to After having an electrical rewire - certificates? in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi. A few years ago we had a full house rewiring done by an electrician who issued a certificate for the work. He also left in the consumer unit...
Hi What would be your thoughts on this one? I bought this property last year, it was rented since 2005. EICR from 2016 states "wiring in fairly...
